Rear suspension work
Someone made a good Youtube video on the matter
Motorcarman ( Bob ) has a shortcut involving the lower plate called the
Suspension subframe as item # 13
Genuine Frame Carrier-rear For Jaguar Xj 1995 - 1997 (from 720125 To 812255) Classic | Jaguar Land Rover Classic Parts
The rear shocks may have a lower attach point solid bushing that should be considered
See item # 17
Genuine Damper And Spring Fittings-rear For Jaguar Xj 1995 - 1997 (from 720125 To 812255) Classic | Jaguar Land Rover Classic Parts
and
What that attaches to can't recall
See item # 17
and
The short answer is NO. But there are several different ways to approach the job, mostly documented in here. Some have used compressors.
I found it relatively easy to undo the body mount in front of the wheel, loosen the rear center of the subframe, take the brake caliper off and let the axle/A-arm drop low enough to let off the pressure on the lower shock bolt and the spring. Then you can muscle out the spring/shock assembly. You can do one side at a time this way.
The following 2 users liked this post by SleekJag12:
Parker 7 (06-15-2023),
Todd Wiens (06-16-2023)
I never could find the video that appeared as a post
I have not done the job
Autozone and other auto parts stores have tool kits including 2 types of professional robust spring compressors to use for free if you go that route
I used the spring compressors kit on some other unworthy car other than the Jaguar
