rear view mirror wire help, please
I'm changing the (failed) rear view mirror in my '95 X300. The wiring from the overhead panel to the mirror has a 3 pin connector; wires colored black (ground?) White/Slate & Green/Red. I presume the wires are 12v+, ground & reverse inhibit. The question is which is which?
I tried a couple combinations on a Gentex 261 mirror, and all I got was an "AIRBAG" code, which has since disappeared. Part of my confusion might be that the Gentex has a 16 pin connector. Can anyone help?
Thanx
Thanx
prestone08 (04-30-2013)
jagent
09-12-2015 01:40 AM
philwarner
09-05-2015 10:05 AM
