Rear windscreen rubber trim
Hi, I’ve got a very slight bit of bubbling in the drivers side bottom corner of the rear windscreen. I wanted to take a closer look and clear out any drainage issues around the outside of the rear window so was wondering does the rubber/chrome trim just pull out or is it glued in? Water does squelch out of this corner when I press it so maybe water is being held there and hence the increased paint blistering here? Can I just pull the trim out, clean it and push it back in or is it not so simple?
hriant88
06-29-2017 06:12 PM
rjrmdarby
12-16-2016 09:45 AM
Vtjaguarlover
01-04-2016 08:51 PM
