Removing wishbone tie from differential
Hi guys and gals,
I am in the process of removing the wishbone tie from a 97 XJR X300 differential. Unlike an X308 where the wishbone tie simply slides onto the tie studs, it appears with the X300 the bushings are bound to the studs somehow. Do I burn the bushings out until the tie slides off the studs or am I approaching this in an obscene brut fashion? Any tip or trick would be appreciated or I give it 15 more mins of burning and then the angle grinder comes out to play. Thanks!
Avro RJ
11-30-2015 07:40 AM
Jaguar Forums Editor
Jaguar Press release
11-16-2015 04:58 PM
Avro RJ
11-16-2015 08:19 AM
