Resolved Intermittent Start Issue !
Hi ,
I just wanted to share my experience with you about my 1996 Daimler six lwb hard start issue , occurring often when the outside temperature is hot ,
In first steps I did :
1) Crank Position Sensor renewed.
2) Intake Air Temp sensor renewed
3) Checked the Cam Position Sensor position
4) Used a good fuel system cleaner with carbon clean effect.
Result : NO CHANGE , in the second step : I see that this happens when outside is hot OR when the engine is hot and stays a little longtime and restart problem ... so I suspected FUEL PRESSURE REGULATOR even there were no sign of problem once the car drives ( pull very well , no hesitation , anything ) and YESTERDAY I changed it by myself and result is : no more start issue !!!
I wanted to share this experience because it is a very easy job to do before going to expensive repairs or changes ,
Cheers .
Cheers .
The following 3 users liked this post by KeremArsan:
steveyd1
12-02-2021 10:51 AM
okXJR
03-31-2015 06:28 PM
