right front fog light bulb replacement
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
1995 XJ6 VDP
June 13
Hi everyone,
My right front fog light is not working and I think the bulb mut be out or burnt
But I cannot find anywhere how to remove thefog light in order to check/replace the bulb
Can someone help me?
Thank you so much
Claude
Durham NC USA
June 13
Hi everyone,
Thank you so much
Claude
Durham NC USA
Received 10,933 Likes
I think you may be referring to the front indicators, as that is the usual way to remove them. I had my fog lamps out some time ago, failing memory but vaguely remember accessing them from behind the bumper, not a big deal.
Right front foglight bulb replacement
I have read here and in other jag forums some horrendous storiez about these fog lights!
No reason to fear. You can get the lights out in about 10 minutes and it is very eas!
Firts thing to do is to remove the big black plastic shield under the nose of the car easier, faster and better (to save the clips) if you use a trim clip remover tool
Once you have removed that shield turn the front wheels to the right for right fog light and/or left for left fog light.
Better and easier if yoy can lift the side you are working on with either the car jack or a floor jack (and make sure you have proper stand/or protection there.
have a flashlight and a normal size flat screw driver;
there are two visible black "clips" about 1 inch wide holding the lamp assembly. The exterior side is very easy to see and reach. Push it toward toward the engine side
The second clip is ab bit further on the inside part of the light (engine side). with a good flash light you will see it. Same operapion kush it toward te outside of car (fender sideà and push the entire fog light assembly out.
After this it is just disconnecting the cable connector and removing the bulb to replace it.
Once done push back in the fog light assembly.
if you have the bulb this takes 2 minutes.
Put back the big black undercover and you are ready to go.
Really easy indeed.
So do not have nightmares about this job, it is a breeze!
Claude
Durham NC USA
1995 XJ6 VDP
1991 Audi 100
Really easy indeed.
Claude
Durham NC USA
1995 XJ6 VDP
1991 Audi 100
GatorJoe (06-17-2012)
Just did the fog light lamp replacement and got to say next time I'm going to try to remove the fog light unit from the front. The side tabs were easy enough for me to press from the rear, so I'm thinking I can press them from the front using a thin putty knife (like I just read in aholbro1's post). It'll be worth a try to avoid removing and reinstalling the plastic under shield.
Tony K
03-26-2024 01:53 PM
rudelover2
09-11-2015 08:53 PM
