Right side power windows not functioning
Old 12-19-2017 | 03:58 PM
RB_jaguar's Avatar
Default Right side power windows not functioning
Had this issue since i bought the car but didnt managed to figure it out.
On the right side of a car both power windows of both doors do not work. They do not work on both doors localy and dont work from a master controler in left drivers door.
Anybody has a clue where start to look for ?
Thanks.
Old 12-19-2017 | 06:00 PM
Lady Penelope's Avatar
Left windows fuse # 15 / 30 amp green LH Heelboard fuse box
Right windows fuse # 15 / 30 amp green RH Heelboard fuse box
Logic relays inside door's switchpack
Gets a ground through the ignition switch for all windows
Old 12-27-2017 | 02:34 PM
Robman25's Avatar
Thanks.
Did LadyPs response help?
Old 07-17-2018 | 09:01 AM
RB_jaguar's Avatar
Lasted long time till i started solving this problem.
I checked the RH heelboard fuses and found that the 15th fuse was missing.
Mounted the new one in and to my disappointment i have only a rear window that started working.
The front right window still doesn't work.
When i push the window button i hear a relay clicking, but window is dead.
Am i having a dead motor issue or is there anything I can check before searching for a spare motor?
Thanks guys
Old 07-17-2018 | 03:45 PM
Robman25's Avatar
If the clicking you hear is in the master switch then it might be that the relay contacts are dirty. I had this on my car.
the contacts would pass voltage but NOT current I removed the master switch and stripped and cleaned the contacts. Then repeat on the inoperative door.
Do not be fooled if the relay ohms out as working!
Old 07-18-2018 | 06:57 AM
RB_jaguar's Avatar
Today started messing with this window.
Disassembled the door panel, all the buttons and connectors.
Checked the motor supplying the direct 12 to the motor. No result- motor does nothing. Measured the resistance with the tester but it shoes no continuity. As if its burned.
Also measured the voltage from the button to motor connector - while not pressing somewhy there is always 12v, when pressing the button down ( relay clicks) voltage goes to 0V
Anyone has a clue, why when pressing button to open the window, voltage drops to 0? or this is normal operation condition.
Window is closed and when i press the button up there is no clicking, only clicks when pressed down.
Maybe someone knows how it should be operating, because know i suspect that failed switch burned the motor supplying in off position the current.
Ma
Old 07-18-2018 | 07:20 AM
Robman25's Avatar
No movement when power direct on the motor shows that the first thing you need to do is find a replacement. I have second hand motors from my XJ40 but not sure if they are the same as the X300 and I am on the other side of the world so probably of no practical use.
Old 07-18-2018 | 07:31 AM
RB_jaguar's Avatar
What do you think about the voltage in the connector?
Now I have a theory that if I have 12 volts with no pressing the window button, that means motor has a current and load.
Can it be that this constant current burned the motor.
My logic tells me that I shouldn't get voltage with no pressing the button.
Maybe the switch button is defected and burned the motor. What if I replace it and it burns again?
I think there could be a window close relay stuck, that caused the motor to burn.
I wonder are those relays repairable or replaceable or its just isn't wort to do that, simply replace the switch itself is probably simplest solution.
Old 07-18-2018 | 09:57 AM
What I found on mine was the locking bar holding the sockets in place was loose , this allowed a socket to migrate and loose contact . Since you have 2 windows acting up I would look at the driver / master position .
In a pinch you can use a battery charger to drive the motor up or down . Just swap polarity on the 2 motor wires . lt's a high current so arcing hazard .
Old 08-06-2018 | 06:59 AM
RB_jaguar's Avatar
The problem was a burned motor and a stuck window close relay.
It appears that the stuck button relay burned the motor.
Solution - changed the window motor assembly and the switch mechanism. Also put the new speakers inside.
Job done.
Lady Penelope (08-06-2018)
Alan Stoldt
12-11-2015 03:33 AM
whiteSTR
01-14-2009 09:39 AM
Quick Reply: Right side power windows not functioning
