Rough shifting when warmed up
Dear Jaguar enthusiasts,
A small introduction. I live in the Netherlands and after a few Jaguars (XJ6 70 - 2x XK8 96&97 - XK 09 I now have my long sought 96 XJR in British Racing Green. Long sought for as a lot of viewed cars had severe rust problems.
Mine has another problem which I dont how to solve.
After around 40 kms when engine and gearbox are hot it starts to shift very rough and fast towards lock up. Even when I do 50 km/hr it shifts up to lock up.
At 100/120 km/hr it sometimes shifts back to 3rd gear.
It has had a proper power flush but as the gearbox does shift very smooth the 1st 40km distance I suspect an electronic malfunction somewhere.
Any suggestion where to look / test and has anyone experienced the same problems and has tips how to solve.
Your tios and thoughts are very welcome and appreciated.
There are shifting solenoids in the transmission controlled by the transmission ECU
The XJR has a GM transmission
The solenoids when hot can drop out and can be read from the connector on the transmission or on the ECU connector down low on the passenger side near the front foot rest
There is a servicing level to the GM transmission , but I don't have one
First thing is the proper service level
Received 10,880 Likes
You can Google "4L80E rough shift when hot" and see what comes up.
Check transmission wiring harness where it enters the transmission. Excess transmission movement can damage the wires.
If nothing concrete is found, replacing the A and B shift solenoids and both speed sensors on general principals isn't a hateful idea. As often as not odd symptoms will be cured. A DIY-able job, but messy. Maybe $200 in parts?
Parker 7 (07-04-2024)
Jaguar issued a TSB regarding fluid level with the 4L80E transmission directing that the level be topped-off right to the "max" line on the dipstick with fluid HOT. I can't remember the rationale for this as opposed to simply using the "safe range" on the dipstick. But they felt it was important enough tp issue a TSB [shrug].
OBD 2 socket has very few transmissions items to code but worth a try
Only 2 solenoids of one resistance value and you have 2 speed sensors of a different resistance value but hard to see a fault as heat expansion related
To find the connector map on page 23 bottom right corner and 81 at the transmission ECU connector
Remember the connector map is looking at the module
Solenoid A / pin 39 to 53
Solenoid B / pin 43 to 53 also
Input speed sensor / pin 37 to 50
Output speed sensor / pin 51 to 36
The solvent flush ( from other transmissions as well in old solvent ) may have freed up some metalic metal shavings to collect on the speed sensors to cloud over their input to the ECU shifting regulation , just wipe clean , but that wouldn't be heat related but still clean to tidy up
In clouded speed sensors the faster the rotations the more the fault shows up ( bunched up deformed pulse waves harder to discern ) , so higher speed related either engine RPM input or driveshaft output ( vehicle speed )
Probably another main large transmission filter change
jagrepair.com/images/AutoRepairPhotos/jagxj1996.pdf
Cafcpete (07-05-2024)
paulzahra
20
10-04-2023 03:59 AM
