Rpm, coolant, fuel injectors, check engine light
Hello folks
So Today the Check Engine Light went on.
I noticed that it had a rough idle the RPMs was high even at cold start, like if i was pressing the gas pedal. Drove the car and noticed it would stay accelerated on its own.
Open the hood to check to see if i could figure out what was going on and noticed that there was some coolant around fuel injectors #5 & #6.
I figure theres a leak somewhere. Maybe a hose,head gasket or even a cracked head
*Any other ideas on what else might be causing these problem(s) Thank You For Your Help/Ideas
Cleaned the coolant out from around the fuel injectors, started the car and no more leaking. I did see that the upper radiator hose has a small leak and I am thinking the fan may have blown the coolant around the engine which is why I thought something was wrong. There is still a rough idle and car still accelerates on it's own.
I have pulled the codes from the check engine light and have gotten PO300, P1313 and P1314.
Any suggestions would be much appreciated.
BrentGardner
28
04-26-2024 04:08 AM
