SC Case Upgrade
SC Case Upgrade
Hey guys,
take a look at this and let me know if this has been done. This case is sold by charles warner at magnum powers and it is intended for the ford thunderbird. that being said take a look at my xjr m90 case next to the mpx case they are very similar. the intake on the mpx looks very promising, am i the only one that thinks this could work? I first had my sc ported but that only took power and torque from the bottom end and placed it at the top end...I would like my car to pull from start to finish. I should be happy, my car is pretty fast as is but i got the need for speed bug.
Its a nice idea but the fixing on the Magnum casing are different to the jaguar vewrsion so you would have to modify the SC mounting bracket. You would also have to make a new throttle body to SC adaptor to mate to the new inlet port. It's all possible if you can design it yourself and have access to fabrication and machine shop facilities. I replaced my Eaton M90 with an Eaton M112 supercharger, but it was big job.
UKnFor-dluv-expat
09-26-2015 08:40 PM
FS[MidAtlantic]: 1997 XJ6 VDP $3,900 - Very RARE Anthracite on Warm Charcoal
42Ajd
09-26-2015 07:04 PM
