In search of fuel rail and trim
Well not a good day on the 95. While removing the fuel rail the connection nearest the bulkhead snapped. So I am in search of a replacement. I believe the part number is NBD3400BB. I am located in Abbotsford BC Canada. Has this happened to anyone before and got the nipple welded back on?
While I am on the search for parts I need a good, with no broken clips BEC10473, this is the plastic chrome trim ring around the shifter. Cheers
Ian
Ian
Parker 7 (01-16-2022)
I snapped mine a few years back….luckily it’s a common part that I was able to snake off of a XJ6. I might have even started a thread on it.
I believe the AJ6 and AJ16 engined Jaguars used the same part. 3.2, 3.6, 4.0, all used the same part. x27, x40, x300
Apprently the supercharged engines are the only ones to avoid. Which should be easy to do.
