Servicing 192K KM / 120K Miles
Hi everyone
I am about to do the 192K KM servicing on my car. I have looked for the service list and found the following :
-Oil change
-Oil filter
-Fuel filter
-Fuel cleaning fluid
-Spark plugs
-Brake fluid
-Cooling fluid
-Wiper blade
Now I know on the last 172K km service I also changed the spark plugs, is this really necessary to do again?
What about the cooling fluid refresh? In the history of my car I have not found a Cooling fluid refresh. When I look at the water its not dirty and looks fine, why do I want to change this?
Anything else smart to do or wise to look while at it?
Cheers!
-Oil change
-Oil filter
-Fuel filter
-Spark plugs
-Brake fluid
-Cooling fluid
-Wiper blade
Cheers!
At the age of the car and mileage covered, I would use a little common sense.
The spark plugs are generally good for 40K kms or better, dependant on fuels used.
I would add a transmission service to the list.
Diff oil would be a good idea also.
Most coolants have a life of approx 4 years. The colour means something, and the fact it is nice and clean is good, but I would drain and refill with new to spec coolant.
I would omit the fuel cleaning fluid, as I rarely use any of those additives, but its your car.
Some grease in the 4 fittings on the half shaft joints would also be an excellent idea.
Wiper refill, well, I do mine every start of winter.
Maraud (10-08-2013)
Received 10,875 Likes
The spark plugs can wait. I think the suggested interval is 48000 km.
I change my engine antifreeze every 2 years even when it looks clean. I don't recall what the factory suggested interval is.
I would add a few items to your list unless you're sure they've been done within the last 48000 km :
-Change differential oil
-Change transmission oil
-Repack front wheel bearings
Maraud (10-08-2013)
Bearing or seal?
A bit of oil seepage from the differential output shaft seal (if that's the area you're talking about) is nothing to be alarmed about. If it turns into an actual dripping leak you might want to take action....or at least increase the frequency of checking/topping-off the differential oil.
Maraud (10-08-2013)
FS[NorthEast]: HOT Black/Black '07 S-Type R w/55k miles for sale!
08Z06
10-24-2015 05:46 PM
