shifter bezel light
Old 09-18-2010 | 09:23 PM
jagman96's Avatar
Default shifter bezel light
i was wondering if the lights around the shifter "p,r,n etc... should light up? it lights up red to let me know what gear you're in, but the other lights not. Also should the transmission selector switch light up? s/n Whats wrong if mine doesn't?
Old 09-18-2010 | 09:40 PM
sempire's Avatar
They should light up, the car I had did, but it was rather dim..
Old 09-18-2010 | 09:47 PM
Doug's Avatar
Yup. Here's a pic:
http://www.jag-lovers.org/snaps/snap...?id=1260063856
It's a tiny little bulb in a rubber bulb holder. Radio Shack has 'em. A dab of blue or green paint on the bulb will be needed for the right glow, if you are concerned.
Old 09-18-2010 | 09:51 PM
Doug's Avatar
Hmmm. Now I'm second guessing myself about the "rubber bulb holder" part. I might be confusing it with another bulb somewhere else. In any case, it's all obvious and easy once you dig in.
Old 09-18-2010 | 09:58 PM
jagman96's Avatar
thanks, what about the s/n switch?
Old 09-18-2010 | 10:39 PM
Doug's Avatar
The sport/normal switch can be disassembled (er...pry it open, carefully) and the bulb replaced. It's a little "grain of wheat" bulb. Radio Shack.
That might be the one with the rubber bub holder I was thinking of.
Old 09-19-2010 | 05:54 PM
jagman96's Avatar
fixed them both, thanks doug
Old 09-19-2010 | 08:06 PM
Doug's Avatar
Did either have a rubber bulb holder ? :-)
Old 09-19-2010 | 08:32 PM
jagman96's Avatar
yes, the one in the s/n switch. advance auto had the other bulb
Jpav27
07-31-2022 07:43 AM
neruda
10-18-2015 02:19 PM
rsa760041
23
09-25-2015 02:33 PM
Phil G.
09-12-2015 08:42 AM
jagtoes
09-09-2015 10:56 PM
Quick Reply: shifter bezel light
