Shifter cable
I had to take the car to a mechanic since the transmission went crazy. Turns out that the wiring harness had rubbed through and was grounding in the console.
I had a trans fluid and filter change, along with a replacement pan since mine was crushed. I also had a MIL light coding for low trans temp. While they wre in there I had them install the last remaining temp sensor harness in the US. Which after exhaustive research located at Terry's Jaguar. (thanks terry)
But the shifter cable is stretched to the limit and I still am on a worldwide search for the cable for a XJR. Any help from you guys would be appreciated.
jimforrest (uk)
02-28-2019 06:42 PM
