Shocks Revisited
Shocks Revisited
I need to put new shocks on my newly acquired XJ6. I replaced them with Bilstein B4s on my last car, but I did not think it made it a better ride. It still felt stiff, and I am looking for a better ride. Would everyone still suggest these, or is there a different shock for a better ride? Not to worried about the cost. Just want the better ride.
I think he is looking for the softer ( comfort ) shock rebound rate with intact components such as the bushings maybe hardened and sloppy.
I have the OEM Bilstein application chart but chasing down an accountants 6 year old battery that lost it's muster in the cold
Received 10,990 Likes
First 24 number is front
It is recommended to change the front lower shock bushing on the front ( X 2 total for car ) as this wears and you can see daylight through the bolt hole
The other different front upper shock donut bushing ( X 4 needed for car , it only applies to front shocks ) gets compressed with age and loose and you can see a gap from the wheel well as well
geneo
05-26-2020 08:47 AM
FastKat
09-06-2012 08:17 PM
