Should I be worried? (video)
After the car has been stored I've started hearing some noise from the alternator or maybe the water pump. It goes away after a minute but appears again if the car has been standing still for a couple of weeks. The airbag warning lamp disappeared after I started it again a second time..
Harmonic balancer slipping ? common on the X300
Paint the dots on the 2 halves and see if they stay aligned after shut down
If bad this will keep the belt from turning the engine coolant pump
https://www.jaguarforums.com/forum/x...lancer-101674/
Don B (02-16-2019)
There is the AC belt pulley on the on the right side
There is some tricks to removing it as the long bolt rust up
There is a cheap Gates brand replacement
https://www.jaguarclassicparts.com/u...-3-2-4-0-litre
Don B (02-16-2019)
Received 10,905 Likes
Don B (02-16-2019)
I'm guessing that the noise will disappear when spring comes and I'll start using it on a daily basis again. But is the noise a sign of a failing alternator? Should I plan already for a replacement?
Sometimes sounds don't come out right in videos. But, judging from the amount and intensity of the sound, I'd be worried about the alternator, yes.
When under a heavy load (after engine start, for example) a bit of additional noise might be expected from the alternator. A slight whine.
What I'm hearing sounds significant, though.
Don B (02-16-2019)
Received 13,087 Likes
Hi Tcasmarcus,
An inexpensive mechanic's stethoscope, available at most auto parts stores, Harbor Freight, Northern Tools, etc., can help you locate the source of your noise without removing the belt. While avoiding moving belts, pulleys and fans, carefully touch the probe to the alternator body, water pump, air injection pump, A/C compressor belt idler pulley, etc.
Cheers,
Don
Cheers,
Don
Doug (02-17-2019)
Lady Penelope (02-17-2019)
update. spring is coming so i took the car out of storage. started it. no sound.. so i started driving.
after a few minutes it came back though. almost like a turbo whine as it followed the rpm of the engine. 20 seconds later it was gone. came back again after 5 minutes but only lasted 20 seconds again. drove the car for a few hours and havent heard anything of this sound again since.. now i have used it daily for a week and the sound has disappeared completely.
i did notice that the alternator belt was not very tight so i tightened it. only problem now though is that once in a while the airbag light goes on. if i stop and start again it always disappears.
will also tighten the ac belt as it felt lose, but not sure if that could in some way be connected to airbag issue..?
i did notice that the alternator belt was not very tight so i tightened it. only problem now though is that once in a while the airbag light goes on. if i stop and start again it always disappears. [snip] will also tighten the ac belt as it felt lose, but not sure if that could in some way be connected to airbag issue..?
Cheers,
Don
A trick to hear bad bearings in pumps or alternators is to use a long screwdriver what we call Stanly screwdrivers its got a square shaft big yellow handle some have the shaft steel go right up to your palm
then place the end on the housing near the pully put your ear to it and you will hear it grinding away.
maybe a socket extension would do.
Last Winter,(has it gone?) I had a squeal from my engine on start up. It stopped after a few miles. I had some work done on my engine, changing drive belts, and it was reported that the water pump was very stiff to turn by hand, also the air con pulley. So I had them changed - noises all gone. The water pump is very notchy and stiff and there is a nice groove worn into the plastics outer pulley face of the other pulley. The belt had clearly been slipping.
Emerald7
02-07-2013 01:48 PM
BadCat
01-29-2011 07:37 AM
HapsburgHC
09-14-2008 02:55 PM
