Side Marker lights front bumper question
Drivers side light module is loose and rattling around in its socket a bit, not in danger of falling out and it looks like you would just push on it from the outside to snap it back in? Does anyone know if this is the proper way or do you need to remove lower cowl and go at it from the inside. My lower cowl has been damaged and is mcgivered together with some wire and I'm not sure I could get it back on if I take it off. I don't want to push to hard on the light from the outside unless, as I think it appears it snaps in from the outside............thanks hope you can understand what I,m trying to ask...
BrentGardner
28
04-26-2024 03:08 AM
FS[SouthEast]: 2005 Jaguar XKR Convertible Supercharged
divingmom
08-25-2015 07:54 PM
