Simple Guide to Head Gasket Replacement on an X300 NA Engine "FAQ"
Old 04-02-2014, 06:36 AM
dfieldsend's Avatar
Default Simple Guide to Head Gasket Replacement on an X300 NA Engine "FAQ"
Don't know if there is one on here, but here is mine.
The following 12 users liked this post by dfieldsend:
AllanG (04-02-2014), BigBossRadio (04-02-2014), Don B (03-01-2019), Doug (04-02-2014), GGG (04-02-2014), JimC64 (04-02-2014), Norri (04-02-2014), RJ237 (04-02-2014), sogood (04-02-2014), someguywithajag (07-02-2015), Vee (03-22-2021), Ziggy (04-02-2014) and 7 others liked this post. (Show less...)
Old 04-02-2014, 07:35 AM
GGG is offline
Received 16,855 Likes on 12,186 Posts
Great guide.
Photos like yours are always a big help to anyone coming to this job the first time.
I hope the oil leak is now history and MoT number 8 has no 'advisories'.
Old 04-02-2014, 08:24 AM
Ziggy's Avatar
Great stuff! Also good to know that it's relatively straightforward.
Your engine bay looks great. Is the cam cover 'just' polished? Should I be buying shares in Autosol about now?!
Old 04-02-2014, 09:13 AM
dfieldsend's Avatar
I saw another polished cam cover on another forum and thought I'd give it a go, simple enough, just takes quite a bit of time to do.
Am currently polishing a set of dimple alloys which I will post up when I get them finished and fitted.
JimC64 (04-02-2014)
Old 04-02-2014, 09:29 AM
Received 6,312 Likes on 5,499 Posts
A good guide.
I've added it to the "How To" section.
The following 2 users liked this post by Norri:
dfieldsend (04-02-2014), JimC64 (04-02-2014)
Old 04-02-2014, 10:04 AM
dfieldsend's Avatar
Old 04-02-2014, 11:17 AM
Received 9,010 Likes on 4,113 Posts
Superb, thanks for sharing....
Nice addittion to the "How to" section too, good catch Norri
Old 04-02-2014, 11:45 AM
JTsmks's Avatar
MY 4.0 just started leaking oil from the exact same spot...great now I have to pull the head! It never ends............................................
Old 04-02-2014, 02:02 PM
FireCrow's Avatar
Absolutely fantastic guide! Even my brother, a complete and utter muppet would be able to follow it! And about the camcover, I've painted mine to the same colour as the body, although it was just a quick job and I knew it wasn't going to last (cheap and rubbish clearcoat). And it just makes me wonder, since there seems to be a lot of issues with magnesium corrosion of those camcovers, isn't the process of polishing them going to speed it up? Don't get me wrong, I love the looks of it, my wife initially wanted me to do that in first place, but it's the corrosion I'm afraid of most.
Old 04-02-2014, 02:09 PM
dfieldsend's Avatar
I have polished three others (sold two) and have a "spare" which I have lacquered, it dulls the shine a little bit, so will keep polishing this one by hand until I decide to replace it with that one. It only goes really dull, no sign if corrosion at all and it's been on for 6 odd months now over winter
Old 04-02-2014, 07:52 PM
EZDriver's Avatar
I seem to have some seepage in that same area. Although it might be coming from the cam cover as there is some mess above that area with some oil detected at the cam cover seal. Other than an oil seepage is there a potential for any other problem related to that?
Thanks for a great post.
Old 03-21-2021, 07:42 PM
Mighty Mac's Avatar
Thank you for that. That will be good for future reference. My area that I am living in this job not suited for that type of work so. Instance I have nowhere else to go I'm thinking of having that done by a mechanic.
Todd Wiens
01-23-2020 03:09 AM
RedXJ40
01-16-2016 06:28 PM
maccavvy
XJ40 ( XJ81 )
12-26-2015 03:30 AM
cadfael_tex
07-04-2011 06:17 PM
wingzero210
04-04-2008 06:29 AM
Quick Reply: Simple Guide to Head Gasket Replacement on an X300 NA Engine "FAQ"
