slow coolant leak in radiator drain plug
I noticed I have a slow leak and found it to be coming from the plug. I'm not even certain how the plug works (i.e. screws in and with what). Is this something I can replace or should I just try to repair it somehow? Is the replacement part available and easy to find? P/n?
Thanks!
Thanks!
Drain Plug # JLM1340.
Drain plug o/ring JLM1499, listed as NLA, so a generic o/ring suffice.
Plug is a dealer item.
O/ring maybe the same or any parts store that has a selection of o/rings.
They get mashed up in the bottom peg of the radiator, and getting them out can require some imagination, but perfectly do-able.
Dan Bennett (05-17-2013)
OkieTim
09-08-2015 04:48 PM
