Sourcing a Mass Airflow sensor
#61
Replaced the CTS and took the MAF off and sprayed it liberally with contact cleaner then left it to dry overnight.
Refitted it and went for a shortish including a bit of max pedal once up to temperature; ran fine although still ticking over at about 1000rpm..
Took it for a longer run the next day and everything back to normal so I don't know if it is actually fixed or not.
have got hold of a used TPS and will look for CPS to keep it company.
#62
Thought I'd update this. For anyone looking for a new standard MAF, the Range Rover P38 MAF which cost ~£50 and is easily available, works very well with X300 N/A cars.An extra groove in the plastic air filter box for MAF orientation has to be cut out as the P38 maf sits the other way around with the plug towards coolant reservoir.
I haven't worried about re-orienting as it fits fine.
Don B (11-26-2019)
davealberta
07-30-2017 06:53 AM
