Spark plugs
There were many previous discussions about spark plugs. Here is Jaguar TSB 05-1-07 [EBC8143 is Champion RC12YC] about what plugs to use, which superseded what was stated in the owner's manual. The purists will stick to Champion Plugs, while many others choose to use NGK instead. I had a terrible experience with a Champion plug in one of my cylinders (read this thread), not sure if it was the coil that killed it or the other way round. I am going to try on with a full set of NGK.
the ngk bcpr6e works fine on mine. i have never quite understood why the ngk are sold as standard option to the x300 though. they are another height then the champion standard ones, but they do work fine.
basically the champion plugs are a standard size called iso while the ngk plugs are jis size. the difference is only 2,5mm so i guess it doesnt matter much?
arath25
09-01-2014 07:23 AM
GvilleVDP
06-06-2013 08:20 AM
dsetter
06-20-2012 10:55 AM
