Speed Control
Hi all, My friend would like to add Speed/Control to his (x300) 1995 3.2 Auto. However as myself has the same model with speed control we have looked at what we have installed up until now, these items being what we see as listed below...
Switch pack on the dash RH Side,
ECU. Speed Control Module,
Actuator with throttle linkage,
S/C Pump.
Dump valve.
As we have not got a workshop manual listing all the parts required, we are stuck on the issues for the brake switch and the clutch link etc. As Jaguar has these car pre-configured for this as all the parts listed above are installed to his as said, it would be great if anyone could let us know what the next stage would be to end this task we have under taken? (EG) Photo,s and or the full fitting instructions from a workshop manual. All info will be gratefully appreciated.
Many thanks to you all.
S/C Pump.
Dump valve.
![Angry](https://www.jaguarforums.com/forum/images/icons/icon8.gif)
Please let me know for why, as we fitted the Speed Control on my friends Jaguar x300 1995 auto last November and all was working as it should. However things are all the same to set the speed etc, but for some reason when to resume the last speed (eg) 60mph,40mph,35mph etc, it does do that with the speed switch to resume, but it takes so long for it to get to the last speed that was set. As on my Jag it all works the way that it should, but not on his now, but when all was fitted to the car it was working exactly as it should. We would be grateful for a quick reply, and thank you.
Johnken
09-15-2015 05:46 PM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
