Sport swich
Well after some reading it looks like this is a linear switch problem. I just so happen to have an extra so I first cleaned them both, looks like someone spilled a milkshake on both, replaced them and still no sport mode.
I checked the switch and the two wires on the outside were getting power, I think one was two volts less than the other,, and the two internal were showing ground so not sure why no light, no sport on the dash and would not go into sport mode
cdma (01-19-2022)
Hmmmm good point. Now if I knew the combo of the switch that should turn it on I could simulate the switch. I think the only other thing it could d be is the transmission module based on the electronic schematic. I think my next type is to try out your theory
Does the x1 side of the switch work? When you flick it on to the x1 side, does that light come on?
http://jagrepair.com
This site has all the wiring diagrams.
Someone recently had the transmission connector ajar
All the fuses to the transmission ECU ?
Is the switch a momentary contact even though it would appear to be one state or the other ?
The shift points are from the inside transmission speed sensor and if faulty it may come from the left rear wheel by default if it is in default, it may not give your sport mode
Can I have a side of BBQ sauce with the crow?
yes the light bulbs can be replaced most of the time they are out you can replace them with LED lights. Be careful with taking the switch apart because it can break really easily. You have to pull the white piece of the switch through the bottom
replaced it with a LED....
but RIP... i broke the switch housing.... put it back together and secured it with some elec tape.....
oh well.... thats what happens with 25 YO plastic i suppose......
If you find a valet switch you can use the same housing after you take a little plastic out of it. I wonder how I know that. You must ensure that you have the polarity right on the led. Take a multimeter and insure all your connections are good
