Stalling Problem but no Check Engine Light or code
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
Hi can anyone tell me if my throttle position sensor or my crankshaft position sensor (or any other sensor) would cause a stalling problem on my 97 XJ6 without generating a code? It seems to happen every time I run the car for more than about 25 minutes. I can be driving 50 MPH or sitting at idle it doesn't matter. Seems to me to be electrical, maybe a bad sensor or ECM. I just bought the car and discovered this problem.
Thanks,
Pat
Thanks,
Pat
It will run for short periods of time and then stall or try to stall. I'm able to keep it running by applying throttle. Don't know if the pump is causing the car to stall or if the car stallnig is causing the pump to short out. I'm beginning to think it's a bad ECM since I'm getting no codes.
Put in a new ECM & TCM and the connectors seemed clean and dry. Now I'm getting a racing motor in park up to 4K RPM's and have to keep my foot on the brake to stay below 50 MPH when I'm driving and I'm still having electrical problem where all of the dash lights come on for a few seconds and then go out. I am now thoroughly confused.
BrentGardner
28
04-26-2024 03:08 AM
X_Type_South_Africa
12-09-2015 05:37 PM
