Stalling's frustrating club of Jaguar x300
#101
Dear friends,
Hello again. Today i have received a used throttle body where the TPS never has been disassemble. So, i have replaced the throttle body that I installed with a new TPS and i have installed the new throttle body with its TPS without to have been removed.
So, i was hoping that problems with the high speed was solved, but the problem persist although now, rpm is around 1.200-1.300 rpm at idle.
I have thought that maybe the problem is that throttle body is not hermetic (although i have put silicon around the the throttle boy joint, but not much) and maybe air enters through the metal joint. Do you know if this can do a high speed at idle??
#102
#103
#104
#105
Dear friends,
Your TPS at idle lets say currently gives 0.6V but the idle voltage value stored in your ECU is lets say 0.54V. This means that they are out of sync and ECU thinks you have your throttle slightly open and your stepper motor never works hence the high idle.
To fix it put the car on the ramp and start it up. From underneath the car undo slightly the TPS screws/bolts. There will be enough play within the holes to move it either side by maybe a millimetre, that's enough for the TPS voltage to move by 0.10V and enough to adjust it and get it in sync with the voltage value currently stored in your ECU. When you get it right, tighten up the TPS. If you cant get the RPM right then it means that the TPS voltage value for idle stored in your ECU is badly out of what it should be and you'll need to reset it in IDS, WDS or PDU or try to replace your ECU.
As a quick workaround you could also get the stepper motor extended fully and unplug it(it extends automatically, I think when you move the key to position 2, wait few seconds and then switch it off, cant exactly remember how its done though). Although not ideal, it would get the RPMs set at ~800.
I can also confirm its metal to metal, although a bead of instant gasket wont hurt.
#107
With respect to whether a gasket is on the IAC valve is in question
From my understanding there should and maybe just maybe if it is missing the IAC final idle position may compensate for no gasket
Vee had a procedure on the IAC valve calibration without removing it ( bolts can snap on removal
There was an example that the TPS value was high like near the 0.70 Dc volts range and the ECU learned that this is the new null
This would make sense that the ECU would slowly learn a " drifting " sensor like the O2 sensors
Do you have a EGR that can be cleaned in the poppet seat ?
The EGR valve has a position sensor to verify it has arrive at it's commanded position
Or a ELM 327 device can see EGR_Error perimeter target value 0 % in all throttle / load ranges
You can also see the EGR position at idle with a simple meter of X volts on the Y color wire
Although the 0 % is ideal but can't be expected in real world
piper 888 (09-18-2023)
#109
No EGR valve on mine..
Funny thing is I had similar issue a few years ago. Bought a made in china LHE1640AA and it lasted basically 5 minutes. Cleaned up the old sensor, and it lasted until recently. Tried again to buy another cheap LHE1640AA but it didnt work.
So I bought an original from Jaguar at 240usd and now it runs for 15 minutes and then the same problem happens again. I have over the last 7-8 years also changed most of the same parts mentioned the owner of this thread, so I am a bit puzzled..
Parker 7 (09-18-2023)
#110
To test the TPS directly and know it is the issue there are 2 ways , one person operation or two person operation :
To see the 0.60 DC volts or abouts reading through the TPS rotation sweep you would nick the insulation on the Green / Yellow wire from the still connected TPS connector as that wire runs over the fuel rail
The valve cover is not a good ground point
Slowly very slowly rotate by hand the TB butterfly shaft and with the key in the run position but engine not started you should see the voltage very smoothly increase toward 5 DC volts
The two person test is through the ECU connector on socket Red 11 and Red 12 with the ECU connector removed , no key in run position
In this test you will be looking at resistance as a very smooth change since your circuit will not be powered by the reference 5 .0 DC volts
Pic coming
Pic coming
#114
Solved?
Pulled a coil and noticed both some oil residue down the well and some white stuff inside the coil. Tip of spark plug looked good though..
The coil is just a year or so, but a rather cheap ebay coil. Replaced with an old, original i had as a spare, and now it runs again. At least it did for my 30 minute drive.. fingers crossed it is fixed. But will have to look at the oil leak..
Parker 7 (09-23-2023)
#115
There was some discussion a while back of wrapping the coils in Kapton tape as a high temp insulator
This would help the arcing to the coil well walls
Might be on need of new O - ring seals as the wells mate with the cylinder head surface
Both easy to find through places like E - Bay
The large around the perimeter seal of the valve cover has some variations on manufacture accuracy as your choice as a package deal to include the well O - rings
This effects your large seal area of the valve cover
There is a D shape cutout on the very back edge valve cover seal that you would have to feel with your finger that it did not fall out of place on assembly
There is an issue with the corners of the D's needing to be filled with high temp silicone as form a gasket may not be temp rated high enough
Just covering the base if you go that direction
Tcasmarcus (09-25-2023)
#117
The white stuff is dielectric grease.
The oil is coming in from a failing cam cover gasket. You have a large gasket that goes around the perimeter, and six rings that go around each spark plug.
Easy to fix.
I recommend using the OEM gasket for the cam cover, but you can go aftermarket on the six plug hole rings.
Easy to fix.
The following 2 users liked this post by Vee:
Parker 7 (09-25-2023),
