Stalls - Trans Speed Sensor?
Old 11-19-2014, 09:14 PM
carter's Avatar
Default Stalls - Trans Speed Sensor?
My 96 Vanden Plas stalls when I slow down to make a stop or turn a corner. I've been informed the speed sensor in the transmission is the problem, because it does not downshift properly causing the stall.
I've never heard of a transmission causing an engine to stall. The repair shop wants $5,000 for a remanufactured transmission.
The check engine light and trans "safe mode" light are on. The speedometer stops working right before the car stalls.
Have you ever heard of this problem/solution before?
Old 11-19-2014, 09:42 PM
Received 12,943 Likes on 6,467 Posts
Hi carter,
Sorry to hear you're having trouble. A counterintuitive but common cause of stalling when slowing for a stop or turn is low transmission fluid. My assumption is that the torque converter does not release properly, causing the engine to bog down and stall. Jaguar has issued a few TSBs on the subject, and checking the transmission fluid level is one of the first steps in the Limp Home Mode troubleshooting flowchart.
There are other potential causes, but that's the first I would check. Also, you should have the stored fault code or codes read. Most of the major auto parts chains will read them for free. Make a note of any codes and report them here.
You can also search this forum for "Limp Home Mode" to compare your symptoms with those others have faced and resolved.
Cheers,
Don
carter (11-20-2014)
Old 11-20-2014, 07:52 AM
RJ237's Avatar
Received 2,801 Likes on 2,236 Posts
If the codes reveal a speed sensor failure, replacing the speed sensor is the cure. It is probably mounted in or on the valve body and should not require removal of the transmission.
I would avoid that repair shop in the future.
carter (11-20-2014)
Old 11-20-2014, 04:37 PM
carter's Avatar
Thanks -- much appreciated!!! I actually reside in Douglasville, GA near the intersection of Fairburn Road and Mount Vernon Road. Thanks for the reply!!!!
James
Old 11-20-2014, 06:43 PM
RJ237's Avatar
I'm the other side of I20. My Autoenginuity will not interface with my 95, but it might connect with your car. If you need some help with code reading, send me a PM with your phone#.
RJ
Jandreu
06-30-2022 03:10 PM
wardo5757
09-11-2015 11:31 AM
Numwen
09-06-2015 12:30 AM
Corycarlo
09-05-2015 11:41 AM
innzane
09-02-2015 10:08 AM
Quick Reply: Stalls - Trans Speed Sensor?
