Starter Relay Switch
Does anyone know the part number for a USA 1996 XJ6 starter relay? I'm looking to replace mine, but I can't find the part number online, or anything online for that matter about the starter relay. Also, are there universal relay's, for example would the fuel pump relay be interchangeable with the starter relay, etc?
Brad Livengood (12-01-2012)
Received 10,988 Likes
I'm not the most mechanically inclined person, but I'm doing my best at learning everything I can. I can def. tell the difference in wire color though.. haha.. so that does helps a lot.
Welcome to the Jaguar Forums. When you have a little spare time, please visit the new members area and introduce yourself and your car.
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
Meanwhile, you will find that there is a forum devoted to XJS, and you will have better results if you ask your question there.
XJS - Jaguar Forums - Jaguar Enthusiasts Forum
Starter solenoid relay is LNA6706AA. It is behind left side headlight assembly. Many used at the two clusters behind the right and left headlights. Sorry, I have not sourced it before. Recommend testing it and/or swapping it with another non-critical relay (like the fog lamp relay) temporarily.
