Steering Column issue
Received 10,916 Likes
You can get a new or used motor & cable assembly. Or, some vendors have been able to source individual cables.....much less expensive, obviously, than buying the motor-cable assembly. Try Coventry West 800 331 2193
The telescope adjustment has it's own motor & cable. Of the two, one is easy to replace and the other....not so much. I always forget if it's the tilt or telescope that's the stinker.
Others will chime in.
The drive cables can be purchased separately for about $50. Alternatively, if your comfortable with a grinder or dremel, you can purchase a 1/4" flex shaft for gas rc boats at a hobby shop and cut it to proper length. Those flex shafts are the right size, but MUCH stronger since they're designed for use in hi-torque hi-rpm racing applications. They run a very cheap $8-12. Also, most weed whackers us the same 1/4" size shaft. The repair shops usually just throw them away when they do rebuilds. If you stopped by a shop & asked them about it, they'd likely just give you one, or at worst charge you a couple bucks.
Reach Motor Driveshaft - Motorcars LTD
Heres a link (with pics) to the repair procedure :https://www.jaguarforums.com/forum/x...teering-42449/
rusty37
04-05-2020 07:40 PM
