Steering wheel adjustment, how much, and how to do it?
Sat in my XJR6 from Japan for the first time the other day as was surprised/shocked at how little leg room there is?! Especially for such a big car (from the outside).
Then thought I must be able to adjust the steering wheel, as it seems quite far forward (my arms are really bent, even with the seat back as far as it'll go) and low down, so my knees have hardly any room.
How can I adjust the steering wheel to be further back and higher up to give me more room? Thanks.
The following 2 users liked this post by Parker 7:
Cafcpete (12-17-2021),
general_piffle (12-16-2021)
Now that sounds interesting! Any idea how to modify the rails, so the seat fits further back on them? Thanks.
Wouldn't surprise me if they simply drilled out some new mounting holes on the rails.
Mkii250 (12-19-2021)
Riding with passengers in the rear seat behind me is a pain for both parties, but you have to make some compromises for those low classic proportions
general_piffle (12-17-2021)
I'm 6ft3 too and have no trouble in my current non sunroof x300 and didn't in my previous sunroof sport. That said, in the sunroof model you really need the seat almost all the way down, if you don't have electric seats, then you'll need to look for one.
Driving with passengers at the back, in a sunroof model, it's a big no-no unless they are children or the car is LWB in which case you can even drive with 3 large lads at the back, it's amazing what extra 20cm of space do.
Steering wheel will have to be set up all the way out, it's a bit short in the sport but manageable.
Parker 7 (12-17-2021)
leave the knob off auto. when you feel it reach the end of its travel let go or you will break the cable. a lot of these cars have broken steering wheel stop switches
i’m 6’4 and don’t have a problem with hitting the roof. just need to tilt the seat all the way up and fully extend the wheel. you can’t drive the car with the seat upright it’s just not happening
The following 2 users liked this post by xalty:
general_piffle (12-18-2021),
It was pretty dark in the garage, but managed to take some photos of the modification.
I forgot to take comparative photos of the stock passenger side, but from looking at the photos it seems they just cut some steel rails and mounted the seat on that, as you can see the rail bolted to the original mounting holes in front of the new ones.
This mod does place the seat a slightly higher then stock though, so there is a tradeoff.
Since i dont need the extra travel i will probably remove the longer rails and go back to stock, just to get that 1cm extra lowering on the seat.
The following 2 users liked this post by bjarnetv:
Cafcpete (12-18-2021),
general_piffle (12-20-2021)
Johnken
07-01-2018 05:19 PM
dmericas
11-24-2016 09:23 AM
carzaddict
08-24-2016 03:35 PM
