Stereo 'Not cont' error
Old 03-06-2020, 03:27 AM
X300exec's Avatar
Must be available still somewhere
Old 03-06-2020, 05:17 AM
katar83's Avatar
There are plenty of Jag CD changers available under £40 on eBay. The Alpine will probably have a built in eeprom for identification with newer AJ9500R, same as the radio itself 24C01. Possibly simple job for someone with knowledge and an ic programmer but at less than £40 its not really worth it, just resell your generic alpine and get a proper Jaguar one.
As I said earlier, generic Alpine will only work with early Jaguars which have an earlier revision of AJ9500R. Later revision radio will only work with Jag CD changers. Starting Vin is in the TSB, think it was 745XXX, but best to check before buying a CD changer. Radio can also be checked, early revision that will work with generic Alpine will have a large resistor in the front right(?) corner, next to transistor with a heatsink, when later revision will not(it has two small SMD resistors instead).
Cafcpete (03-06-2020)
Old 03-06-2020, 05:44 AM
X300exec's Avatar
I can’t find an affordable later cd changer for mine ,not paying 200 quid for a remanufactured one ,I’ll just sell the alpine one and give up 🤦‍♂️
Old 03-06-2020, 07:04 AM
Cafcpete's Avatar
You could always get an aux input instead
https://www.discountcarstereo.com/?t...&including=all
Old 03-06-2020, 07:11 AM
katar83's Avatar
https://www.ebay.co.uk/itm/CD-MULTI-...gAAOSwgApdeLAB
£60. I did see few earlier last month that were cheaper than this.
Old 03-06-2020, 07:22 AM
X300exec's Avatar
move put it in my watch list cheers
Old 03-06-2020, 08:04 AM
Rodders's Avatar
If and when I make progress I’ll keep you posted. In the meantime I’m enjoying FM radio
The following 2 users liked this post by Rodders:
Cafcpete (03-06-2020), X300exec (03-06-2020)
  #28
Old 08-26-2021, 06:26 PM
ETexJag's Avatar
So the old "CD NOT CONT" reared his ugly head here in East Texas in my 2006 XKR convertible.
I saw the referral to Southern Electronics, so I sent the head unit in to them.
They said the unit was un-repairable, so they sent me a replacement.
Installed the replacement, and it didn't resolve the issue.
They were also so kind as to include a new cable, which I tried (just running on the outside of the car) - still no luck.
So I played around by swapping some of the cables in the truck at the stack, and bypassed the navigation unit,
and was able to see the cd playing on the display on the head unit (but no sound),
so I thought maybe the nav unit was bad and not passing through the cd signal.
So I found a used nav unit (identical model number), but still have the same issue.
Thinking about looking for a cd changer, but I hate to keep just replacing parts, so I thought I would reach out to the forum.
Anyone have any suggestions?
TIA
Mike
Old 08-27-2021, 02:46 AM
Cafcpete's Avatar
Sorry Mike, you have posted in the wrong forum so not much shared know how here.
Out cars use a different system.
You will get better targeted info if you repost in the appropriate place
mkthonak
04-12-2020 03:58 AM
X300exec
02-28-2020 02:04 PM
ablack
07-26-2019 11:48 PM
greenforest56
01-27-2015 05:49 PM
rparker
Audio/Visual Electronics
09-03-2008 10:26 PM
Quick Reply: Stereo 'Not cont' error
