Sticking in Park once in a while
It sounds like a simple electrical fix. On my xj6, park wont disengage unless the footbrake is engaged (as a safety feature) nor will it attempt to start unless it is in Park or Neutral, thanks to a "Start inhibitor switch" which should be located beneath the gear shift gate/cover. A little look around should reveal the problem, perhaps the switch has come loose, or an electrical connection has. Check and clean any connectors you might find under there. Hope this helps.
n2audio
17
10-09-2015 10:53 PM
DFW
10-01-2015 07:22 PM
