Sticky Throttle 1996 XJR
Just wondering if anyone has some input on my sticky throttle.
The engine idles a little high but when I tap the pedal it calms down. I just lubricated the cables thoroughly but it turns out it is not the cables. In fact it does the same with the cables disconnected.
I also hosed down the linkage at the intake as best I could but no change yet.
Just wondering if this is a common problem with an un-common fix
Aaron.
Aaron.
xjrjag
09-27-2015 01:53 AM
