Sun roof lubrication
I actually drove around for a bit with the sun roof open. It opened and closed smoothly but when I got home I noticed the rails were a little sticky with old grease I presume. I'm thinking about cleaning them up and adding some new lube. Any suggestions on what to use. I have white silicone grease but I'm not sure if that's the best choice. Anyone think something else might be more appropriate? Thanks.
Lots of TSBs on the sunroof
Some Youtube videos
See section 13
JagRepair.com - Jaguar Repair Information Resource![Icon Dance Disco](https://www.jaguarforums.com/forum/images/smilies/icon_dance-disco.gif)
The same sunroof on the X308 ( V - 8 ) model
Some Youtube videos
See section 13
The following 2 users liked this post by Parker 7:
motorcarman (06-09-2024),
PBoudr (06-08-2024)
Parker 7 (06-09-2024)
G’day P,
You can buy the chain lube in cans with a thin plastic tube as part of the nozzle which allows you to lube all the hard to get to bits. There is quite a lot of solvent in the oil when you spray it which eventually evaporates leaving the oil behind on all the components.
Cheers,
Jeff.
Cheers,
Jeff.
