Surgery on the nuts: cutting off those stupid deforming lug nut caps
I found a set of spare lug nuts for my XJR that must have been quite abused by a previous owner, because they wouldn't even accommodate a 7/8" (22.2mm) socket on them, much less the correct 22mm one. On a whim, I decided to cut the covers off and see if I could do something with the separate pieces. As expected, the usual open-ended nut was underneath, and it measured exactly 21mm as confirmed by my digital caliper.
As it turns out, there's a lot of aftermarket plastic slip-on lug nut caps that are supposed to fit a 21mm nut, so I may get a cheap set of those. Alternately, I may try to reform the shape of the original cover by simply hammering it or pressing it with a hydraulic press. The main issue is whether or not this would cause problems with the trunk toolkit in case I have a flat tire and need to remove a wheel; not a problem in the workshop, but definitely so on the side of the road.
Parker 7 (11-29-2022)
labcoatguy (11-29-2022)
Vipercf
23
06-14-2015 09:55 AM
