Suspension question, springs shock, etc.
Hi everyone, I have a 96 XJ6 and have always had a alignment problem with my car. The previous owner of the car did have a accident in the right front which I have a feeling thats the reason the car my pull to the right. I was also told that my suspension is a little lower on the right side than on the left. is there a way to correct this? I will get the alignment done and after a couple weeks it will start turning to the right again. I have noticed that all of my tires are wearing from the inside. What can cause this? I have replaced pretty much everythign from shocks, ball joints, tie rods, rebuilt rack n pinion, sway bars, pretty much the whole suspension, only thing I have never messed around with is the springs. Thanks everyone.....
A good alignment guy should be able to determine if the car itself is out of whack. But I am finding fewer and fewer good alignment guys out there! I would enquire with a quality body shop that has a frame "table" that can find weirdness with a frame/chassis and straighten it. Might be pricey...
Tar
09-06-2015 11:24 AM
