Suspension Repairs '97 xj6 4.0 VP
Have been working on suspension on '97 xj6; lower shock mount bushings in control arm specifically, so thought Id share the success of this project. Found a thread on here earlier last month where a guy tore the control arms apart to access the bushings in order to cut them out and replace. Good news to future enthusiasts: you dont have to remove the whole control arm assembly to accomplish this. Remove wheel, remove sway bar link, chisel out center soft metal and rubber inserts of the bushing- once you have the guts removed, you can easily use a single ended frame hacksaw to cut through the bottom length of the bushing, once through use a chisel or flat tooth screwdriver to get between and under the severed parts and start tapping it out- should take no more than a half hour total. New bushings should be started in from rear side of mounting boss, from back of car to front as they are slightly tapered bosses. These were easily pressed in using a grade 8 bolt, a spacer bushing and some flat thick washers of appropriate size on either side of bearing and boss to Pull/Press the bushing in, you'll need a box end wrench and a deep well socket/ratchet. Use a little white lithium greace inside bushing boss and on bushing outer surface, they went in rather easily and very snug and they seat well. I had to adjust and resituate the washers and spacer due to depth restraints and such regarding the threads of the bolt, etc, but the keen DIYer should be able to figure it out as he/she goes along. Really simple and quick fix. Hope this helps.
cool (03-18-2014)
Welcome!!
Don B (03-17-2014)
SJC you mention " once you have the guts removed, you can easily use a single ended frame hacksaw to cut through the bottom length of the bushing, once through use a chisel or flat tooth screwdriver to get between and under the severed parts and start tapping it out- "
would you kindly elaborate this part as it seems vague, just wondering if you can already push out the bushing why cut the the bottom length of the bushing? would you share picture of the cut bushing?
On the forum we use the factory model codes to distinguish between all these models. Daphne is therefore an X300.
Since the pics I found were on this forum I didnt feel compelled to post more pics, as they were same as mine except I chose not to remove the whole control arm upper/lwr assy. I'll try to find the thread again and post a link to it. Here is the lower shock bushing: New Jaguar Front Lower Shock Bushing CAC75851 | eBay
The center "guts" include the center bushing that the mounting bolt passes through and the rubber shock absorbing material around it. When these go bad, the center bolt pass-through-bushing will usually have started to separate from the rubber absorber material, this will push relatively easily out, then you can tear the rubber absorber material away from the outer bushing casing (which will have been pressed into the lower control arm shock mount boss- the round opening it is pressed into). This outer casing/race, that has been originally pressed into its boss is what has to be cut through length-wise and pryed away and out of the boss.
Sorry, not able to locate the thread with the pics. the guy had photo'd his tear down and install. If I come across it, I'll post it.
Here is another good link though, for past repair projects and training/maintenance manuals: JagRepair.com - Jaguar Repair Information Resource
The following 3 users liked this post by sjc1997xj6:
BigBossRadio (03-25-2014)
I went to several sources: try Jagbits.com, partsgeek.com had a lot of the items I needed, and check ebay for your specific parts. I used aftermarket parts and all have worked out well and seem to be high quality parts. I also check the reviews from past consumers and do some research on the part suppliers. partsgeek was very helpful and good communication, and the jag guys on ebay have always come through well for me. Hope this helps!
The following 2 users liked this post by sjc1997xj6:
BigBossRadio (03-25-2014),
Lawrence (03-24-2014)
Yea sorry saw that after, is it a difficult job cutting the outer bush casing?? just that if you make 2 cuts opposite it will just fall out surely.
NOTE: when you install the new shock bushing, you must install it in from rear side of its boss and press it in twd front of the car. These bosses are slightly tapered, and you know it until you try to drive the bushing in from the front as I tried to do the send side! spent a 45 minutes trying to get it seated/started before guessing it was a one way install, and sure enough, starting from the rear it was installed in less than 5 minutes! I used a little white lithium grease on the inside fo the boss and the outside of the bushing casing, seated it in the outside rim of the base and tapped it in until it held in place under its own friction, then installed the makeshift bolt-washer-nut press and pressed it the rest of the way in. Once you start the pressing it will start off a bit snug, but continuing force seats the bushing nicely and it follows through pretty smoothly. I did both in the same day. could probably do them again, both, in less than an hour if the task ever came up again.
SOMEWHERE on here a guy has good pics of the process he used, tearing the control arms all the way down, and he has pics of the bearing and its guts being cut/pulled out. Darned if I can find the post though. It's what lead me to start the project and able to complete it.
Hope this helps.
Steven and Daphne!
BigBossRadio (03-26-2014)
