Tachometer readings strange
Gotta start somewhere.
Good luck!
b72hugh (03-27-2012)
Thanx for the direction. New to the jag's.(and love it when its running)
Using a Noid Light, which plugs into the fuel injector terminal at the injector, it appears i am not getting signal to the #1,2, and 3 injector.
I pulled the ECU off and there are signs of corrosion at the connection.
I will clean the terminals up. And coat them with Dielectric grease?
Do I dare open the the covers on the ECU?
Good luck!
I opened up my ECU only to find someone had made some mods in the past.
I have 2 wires that are broken that someone soldered onto the inside and joined into the harness.
I will do some soldering to patch this up.
The " black side" wont open unless i release the clips on the heatsinks, correct?
Good luck!
b72hugh (03-30-2012)
philwarner
25
06-26-2021 05:43 AM
1964Daimler
09-09-2015 11:28 AM
