Tail light issue
Tail light issue
My dash light for a tail light bulb being out flickers when I drive and goes on when I apply the brake pedal. The bulb in the holder is good. This is the bulb setup on my passenger side. When I turn on the right (passenger) side turn signal the dash light for a bulb outage also flickers. How can I fix this? Is it a ground issue?
Received 2,192 Likes
I suspect you have blown the formerly working stop light circuit by overloading it. Each stop lamp is on a separate circuit so that "BULB OUT"can be determined. It is a known defect in the SCLM, (Security and Locking Module) to short an output device called a HSSSS (High Side Solid State Switch). You can replace the SCLM without reteaching the keys, but the key fob is married to the module. Make sure your replacement SCLM has the same fob frequency and yiou can marry it without too much drama- see archives.
Vtjaguarlover
12-06-2015 04:09 PM
