Taillight problem
You can find it in the trunk in the plastic container, it is closest to the battery. If you Google "lamp control module jaguar xj6" you will see pictures on how it looks. The Lamp Module is easy to open and too see if the diode is broken you can compare it to the others. If it is broken you can easily replace it with a new if you can use a soldering iron.
dragonfly777
Regional
09-08-2015 01:39 PM
