Temperature gauge??
I've read numerous posts criticising the effectiveness or accuracy of the temperature gauge. Mine rises to just shy of 12 O clock, almost vertical and sits there. The only time it ever fluctuated was when my thermostat went bad, but it returned to "normal" once the stat was addressed.
But yesterday, I noticed that my fans weren't running. They usually come on once the ignition is switched on. I don't honestly know how long this has been the case and today, I double checked their lack of activity, before, during and after a short journey. The temp gauge rose as normal to it's usual
resting place, with no change there. The weather is quite cold here at the moment (cold for us!) so it might worry me more in the summer time. I will check fuses and relays etc. tomorrow, but in the meantime, what's the story with the temp gauge.
Surely it's not a lot of use if it's more decorative than informative. Is there any aftermarket solution or alternative? It seems a bit crazy to leave your engine at the mercy of such an ineffective "warning device".
Thanks in advance.
Thanks in advance.
Received 10,916 Likes
Just because the fans are not running doesn't automatically mean the engine is running hotter.
The engine temperature is finely controlled by the thermostat opening and closing to regulate flow through the radiator. Certainly in winter in driving conditions I would not expect the fan to be required. It would only be needed where the thermostat was wide open and the flow of air through the radiator from normal forward motion was insufficient to cool it, ie for sustained period at idle or in slow moving traffic.
