Is there a way to get read the Check Engine error code without scanneron xj6 1997 ?
Replaced altenator, everything works fine, but Check Engine light poped up. I am hoping it will clear, but to ease my mind I would like to know what is the error. Is there a way to get the code without the scanner tool?
I think the answer to the actual question is no. Unlike some vehicles where you can prompt the car to give you a series of coded flashes, the X300 needs a scanner ( except for the HVAC which will flash numbers corresponding to faults)
