thermostat install xj6
is there anyone who can give me a little advice on install of a housing and thermostat on this car. i got the thermostat and gasket ect then started to tighten down the housing and a bolt "ear" snapped off the housing. did i have the gasket position wrong. i dont remember that there was even a rubber gasket when i took it off. but when i put it back on i was given one to use. and can i reuse the metal gasket that goes on the housing. does anyone have video or picture. thankl you for your time.
The thermostat is the same for the XJ40 and the X300.
The rubber ring is for the XJ40 (AJ6) and the thin gasket is for the X300 (AJ16).
I have several thermostat covers in my pile-o-parts with the mount ear broken. They can be welded but knowing the difference is the key to not breaking them in the first place.
bob
bob
littlelic69 (02-23-2016)
I was given the O-ring too and did a mock up before inserting the t-stat housing screws and it didn't seem to mate up good so I just used RTV on the housing. Still working 2 years later.
Jaaaggg
05-01-2017 02:43 PM
hawaiianjag
02-22-2016 05:49 PM
