Throttle Body Gasket...or Not??
I want to remove my throttle body for a proper cleaning and in past digging through related posts, cannot determine whether there really is a gasket needed behind it or not. Does anyone know the final answer I need before I pull it off...should I have a gasket to put on or is none needed?
Oh yeah ...1997 XJ6 VDP which makes it a 4.0.
Thanks in advance!!
Bob
![Icon Redface](https://www.jaguarforums.com/forum/images/smilies/icon_redface.gif)
Thanks in advance!!
Bob
Received 2,191 Likes
no theres not, if youre uncomfortable without one apply a very thin layer of hyloseal to the mating surface or thin layer of grease works too. you only want a seal of scrathches if there are any. This is a machined surface on both and jaguar felt there was no need. Although all later engines they evidently feel as confident about since they added either orings or gaskets to them.
someguywithajag (05-16-2021)
no theres not, if youre uncomfortable without one apply a very thin layer of hyloseal to the mating surface or thin layer of grease works too. you only want a seal of scratches if there are any. This is a machined surface on both and jaguar felt there was no need. Although all later engines they evidently didnt feel as confident about since they added either orings or gaskets to them.
![Icon Angel](https://www.jaguarforums.com/forum/images/smilies/icon_angel.gif)
SORRY COULDNT PASS ON THAT 1
Thank you TopHat. I was considering simply cleaning the mating surfaces well and assembling metal to metal, but if I could end up with idol problems that way, I will absolutely use a bit of sealant. I do not want any uncontrolable power surges in my 4.0!!!
![Icon Sultan](https://www.jaguarforums.com/forum/images/smilies/icon_sultan.gif)
I did get mine off easily and got it cleaned up. I posted some pics that might be helpful to someone who hasn't done one before.
https://www.jaguarforums.com/forum/a...p?albumid=1879
The touchest part was removing the TPS. The screws did not come out easily!
TopHatChef, you're probably right in that a previous owner might've used a curing sealant putting yours back together. However, since it is a flat, face to face mating between the TB and intake, I wonder if you'd be able to break it loose with a couple of screwdrivers placed in the mounting bolt holes and pry it off that way?
When I reassembled mine, I ended up using a thin film of grease as I couldn't find any Hyloseal (as Brutal suggested) locally. I did find out though that Permatex began selling Hylomar Universal Blue; a non curing sealant and I'll have to find some. I want to add that to my tool box for sure.
Thanks for the input Brutal and TopHatChef!
By the way TopHat, are you actually a chef? My son began cullinary classes last year and hopes to make a career of it.
Bob
Bob
Guest
Posts: n/a
I can confirm on a 1997 XJR6 that there is no gasket between the throttle body and the superchartger bypass valve manifold. Even though there was no gasket, the TB was still quite stuck to the manifold and took a sharp whack from my hand to pop off. But the mating surfaces look clean with no sealant other than some minor corrosion. I think the oil from the crankcase ventilation, water and minor corrosion after 20 years just had them stuck fast to each other.
I've ordered some of the Permatex 85249 Hylomar mentioned above though for my reassembly just in case and I'll probably take some 1500 or finer grit sandpaper to the surface to clean it up.
It is odd that there is no gasket though. Even the SC bypass valve manifold has a gasket between it and the SC just inches away.
al_roethlisberger (04-17-2017)
Thanks, would you recommend the Permatex Permashield 85420 over the Permatex 85249 Hylomar? Both seem to have good specs and are non-hardening/non-setting.
Where is there an o-ring on the IACV that would need replacement?
The following is an interesting thread discussing factory recommendations for Land Rover applications of sealers, etc:
Hylosil or RTV- any differences? - Land Rover Forums - Land Rover Enthusiast Forum
I suppose either would work, however for some reason, I feel I would go with the 85249 Hylomar product! Both are fuel resistant, which is what is important.
If you remove the two small 5.5mm bolts, you'll be able to pull out the IACV and notice a crushed orange rubber o-ring around the cylindrical piece that inserts into the hole of the throttle body.
http://winkay1.m.ec21.com/mobile/pro...uct_id=9589524
That picture should show the orange o-ring.
al_roethlisberger (04-18-2017)
rominempire
28
10-08-2020 10:39 AM
FS[NorthWest]: XJ8 / XJR 3" Mina Gallery Intake Pipe only (For X308)
xjrjag
10-12-2015 03:16 PM
