Throttle body TPS part same or different for NA and SC (XJR)?
Just curious, does anyone know if the throttle position sensor (TPS) potentiometer on the normally aspirated XJ6 throttle body is the same part number for the TPS on the XJR throttle body?
I have another XJR throttle body, but no TPS on it. So if the TPS is the same part, that makes my search a little easier as the pool of used units is a bit wider.
Some quick searching seems to indicate they are the same part JLM 12074 , but wanted to confirm.
See this thread discussing the TPS and recalibration after TPS replacement. The thread mentions a cheaper Ford TPS halfway down the first page but I don't know how successful this was. Maybe worth a try as it is a fraction of the Jaguar price for what is after all a very simple component.
https://www.jaguarforums.com/forum/x...rt-help-73922/
al_roethlisberger (03-19-2017)
odisyus
23
01-19-2016 11:14 AM
FS[Western US]: XJR Spring Set- X300 model - Lower, Stiffer, Better Handling
XJsc-guy
01-04-2016 09:42 AM
