Thumping Sound Coming From Front Left
Every time I go over any sort of bump, there's a thumping noise that comes from the front left of thwe jag, (it feels almost like it's under me.) My shocks may be getting worn, but from past experience, worn shocks have not made that sound before on other cars I've had. It would cost me over $400 that I don't have right now to replace the front two shocks, so is there anything else that it may be or if you think it is the shocks, is there any way to prolong them? I jacked the jag up and looked under to see if there was some exhaust hanging down or something, but everything was perfect under there so it wasn't what I thought....
It's one nut on top of the shock. They mount under the hood. Romove the nut and pull the shock out of the hole. Replace the bushing on the bottom side and top side. Besure to reuse the large washers and watch orientation so you put them back together the same way. You might have to move the power steering reservoir and the coolant reservoir.
Adding to the above comments: If I remember correctly, you'll need two wrenches. One to hold the shock in place and one to loosen the nut securing the bushing. If you do decide to replace the lower bushing you will have to remove the wheel. Also, make sure you support the axle and brake disk while trying to replace the bushing or you might have the spring come off.
Mike
Mike
There isn't any where on the shock to hold the shaft with a wrench, that is why I stated above that you need a impact. You could try and use vise grips and a towel but, I wouldn't. Removing the wheel is a must and there isn't enough control arm travel to let the spring fall out.....unless you have other problems.
BrentGardner
28
04-26-2024 03:08 AM
