Tie Bar dimension questions- updating to rear sway mount on X300 1995
I picked up a rear tie bar with the sway bar mounts (Thanks Sandurz!!).
I measure the differential mounting holes as 11/16 (17.46mm).
Who know the diameter of the X300 differential studs?
Do I have an x300 sway bar tie plate or an x308 sway bar tie plate?
My understanding is that the X308 diff studs are smaller diameter than the x300 diff studs.
If I can get stud OD from each type car I can confirm my mount before disassembling and also make appropriate bushings if need be.
Thanks in advance!!!
Ric
Ric
