Torque Rating?
You mean the axle shaft hub nut for the first one? That is 304-336 N-m. The manual has the following notes:
The axle shaft nut is a self-locking item with a thread insert and must NOT be re-used. Assembly and fitting is the reversal of this procedure taking note of the following:
-Prior to assembly, remove all traces of old adhesive from hub splines.
-Loctite 270 Adhesive should be applied to axle shaft splines over a radial area of 30 to 50%.
-Renew all bolts that were originally fitted with thread locking adhesive.
-Check and adjust rear wheel camber setting.
-Verify operation of brakes.
The lower shaft is 80-100 N-m
