tramlining - a possible cure
Old 02-04-2014, 03:59 AM
doc's Avatar
doc
doc is offline
I have the original upper control arm bushes developed by one of the guys on the old XJR6 forum made a slight improvement to the tram-lining
Then went to 235/50/17 tyres problem solved
I also have Andy,s rose jointed sway bar links they make the front really tuck in nice in corners
The 235/50/17s also make the rear come out if you switch the traction control off easy power on over-steer
I searched for matching 255/45/17s so I could have the larger tyres on the rear but no manufacturers make them with matching tread patterns so its one or the other
car also drives nicer on crappy roads not so rough an acceptable compromise
Old 02-05-2014, 02:20 AM
plums's Avatar
Received 2,181 Likes on 1,621 Posts
Exclamation left turn!
continue on
or turn left for an allied topic:
https://www.jaguarforums.com/forum/x...41/#post904674
Old 02-05-2014, 02:03 PM
XJRmac's Avatar
I did exactly the same to my x300 xjr used to be all over the road was like being in a speedboat, put the narrower tyres on and it cured the tramlining completely, certainly a lot cheaper than replacing all the bushes if you get some part worns on ebay, paid 40 a corner for some merc tyres and would highly recommend it
Old 03-14-2014, 05:22 AM
plums's Avatar
Default bmw m3 vs z3
for what it's worth ...
apparently the bmw z3 is notorious for tramlining in stock form whereas the m3 is not.
this is true even though the z3 running gear is based on m3 running gear.
the difference is the rear front control arm bushing on the z3 has voids in the rubber whereas the m3 does not
the complete cure for tramlining in a z3 has two parts:
1. replace steering rack bushings with poly bushings
2. fill voids in control arm bushings with plastic "fillers" which are available for that vehicle from the aftermarket
vwbusbits
10-13-2015 03:43 AM
bydand
09-28-2015 09:47 AM
bydand
09-27-2015 12:00 PM
Roman fellow
09-26-2015 10:19 AM
Balboa
09-05-2015 11:32 PM
Quick Reply: tramlining - a possible cure
