trans. fluid
Hey folks-
Quick question if you don't mind, what transmission fluid would you recommend for a fluid replacement in my 1996 xj6 4.0litre. I have about 107k miles on it, I was thinking about adding theLucas transmission additive to the fluid as well, has anyone used this before, is it safe for this transmission? I have used the Lucas trans. before, I just wondered if anyone has had experience with thisadditive in our transmissions. Thanks guys, I appreciate it.
-James
-James
I just did a transmission service on my '95 XJR, and i used the lucas additive, but make sure you know how many quarts you need, because the lucas additive makes it impossible to get an accurate reading on the dipstick. I also have a '96 XJ6 and it's been 4 qts every time. As far as fluid type I've always used Castrol Dexron VI.
Received 2,190 Likes
Received 10,871 Likes
ORIGINAL: panchostatus
You probably already know this, but just in case......
To get an accurate reading with the 4L80E you gotta drive it till its really hot....a good 15 miles or so.
And top it off right to the "Max" line on the stick, as per Jag tech bulletin. I had a delayed engagement problem with my '95 XJRwhen the fluid level was simply in the "acceptable" range on the dipstick.
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
dmatthewman
09-30-2015 10:10 AM
