Transmission Drain Plug
Hello. I am returning member, but had to re-register. I just picked up a 1996 XJ6. First off, I want to do several drain-and-fills for the trans. I can't get my fat head all the way under the trans pan to get a good enough look, so I am hoping someone here knows what sort of drain plug I have. I see what looks like a thick washer-type plug with a torx or allen head center. It is in the center of the pan. I just want to make sure I have the tools I need before I really shoehorn myself under there for the task. I also don't want to remove something that is not a drain but will harm the trans.
Thanks in advance.
Thanks in advance.
It's a 5mm allen plug. See this procedure here: https://www.jaguarforums.com/forum/x...cement-164781/
placer61 (07-11-2021)
H5 Allen
https://www.jaguarforums.com/forum/x...-fluid-149399/
Good to find a plug, there....not all were so-equipped and you have to drain by loosening the large nut on the fill tube/dipstick
xalty (07-12-2021)
For easy drain and refills, I just like to use a pump through the dipstick tube. No crawling around under the car necessary. Park the car tail up to force more fluid forward, let it sit overnight, then pump away! I emptied into an empty gallon jug, noted the amount taken out, put back in the same, Done!
l3uddha
06-16-2016 11:21 AM
Terry H
10-18-2013 04:14 PM
